RE: UMS Evolution Radial Care and Operation
<span id="result_box" lang="en"><span class="hps">Hello</span> <span class="hps">all</span> <span class="hps">engines</span> <span class="hps">fans</span>
<span class="hps">I have flown</span> <span class="hps">my</span> <span class="hps">best</span> <span class="hps">7-35</span> <span class="hps">with</span> <span class="hps">18x8</span> <span class="hps">prop</span> <span class="hps">from</span> <span class="hps">menzs</span> <span class="hps">wood.</span>
<span class="hps">now</span> <span class="hps">from</span> <span class="hps">Graupner</span> <span class="hps">18x8</span> <span class="hps atn">"</span><span class="atn">G-</span><span>Sonic</span><span>"</span> <span class="hps">looks like</span> <span class="hps">APC</span><span>, but</span> <span class="hps">cheaper</span><span>, rpm</span> <span class="hps">6800th</span>
<span class="hps">My</span> <span class="hps">PT</span> <span class="hps">17</span> <span class="hps">Stearman</span> <span class="hps">weighs</span> <span class="hps">6.5 kg</span> <span class="hps">and there</span> <span class="hps">is</span> <span class="hps">no problem at all</span><span>,</span> <span class="hps">is power</span> <span class="hps">over</span><span>.</span>
<span class="hps">I</span><span>'ve tried the</span> <span class="hps">18x10</span> <span class="hps">but there</span> <span class="hps">was nothing</span> <span class="hps">good</span> <span class="hps">flying weather</span><span>, so I</span><span>'ll be back with</span> <span class="hps">the</span> <span class="hps">test</span>
<span class="hps">Lars</span></span>
