RE: Roto motor 35FS
Hi,
I am also looking for information about the RotoMotor 35FS, I thought it could be a good engine for my TC Piper (22 pound 110 inch wing span). I like the sound from those 4 stroke engines, but unfortunately your experience sounds not like the best experience you ever made with an RC engine. This engine is simply to expensive not to be the BEST.
But maybe you were simply unlucky and after the problem with the ignition is solved now the engine will be perfect.
However, I will also check for other engines, befor the final decision will be made.
Chris
