RCU Forums - View Single Post - Classic Pattern at the Bear Mountain Flyers Fall Pattern Meet - Oct. 1 & 2
Old 09-20-2011 | 08:36 PM
IH82Roll
Default RE: Classic Pattern at the Bear Mountain Flyers Fall Pattern Meet - Oct. 1 & 2
Here is a link for the pre-registration form for the contest. http://www.patternflying.com/TempRegistrationPage.aspx If you are competing in the classic pattern put "(CP)" to the right of your last name, so we can get an idea who is interested. If you are entering both AMA and classic, you can put "(both)" to the right of your last name and select the AMA class you wish. You will still have to select an AMA class either way at the bottom.....not much we can do about that at this time. Any direct questions about classic pattern, go ahead and contact Tony F. for the details. Looking forward to seeing you all at the contest.
Mike G.
