RCU Forums - View Single Post - Prop question
Old 09-21-2011 | 03:48 AM
Rudolph Hart's Avatar
Rudolph Hart
Default RE: Prop question
All you need to do is hold one side of the prop and gently nip the prop nut up for lectric mostly.The engine manufacturers/warrenty people have already seen enough stripped threads to last them a lifetime.Aav if you let the engine run enough it will create it's own clearance re spinner backplate and cowl
