RCU Forums - View Single Post - Inrunner stuff
Old 09-21-2011 | 09:53 AM
MachLoop's Avatar
MachLoop
Default RE: Inrunner stuff
ORIGINAL: gaRCfield
Also should I be able to 'wiggle' the motor with only the front mount installed? Or is my 'soft mount' too soft?
There is definitely some vibration.
The developer of the soft mount is the best resource to tell you how it should behave at rest and under load. "Back in the day" when flying glow I used at least 10 different types of soft mounts over time before settling in on the Hyde mount. The Hyde mount secured the engine at two points and was both firm and allowing very limited movement. I used other soft mounts that allowed very visible movement at the lower RPMs - scary movement. But - they held and were overall secure.
