RCU Forums - View Single Post - Roll axis trim changes with airspeed change.
Old 09-21-2011 | 01:13 PM
DAN AVILLA's Avatar
DAN AVILLA
My Feedback: (12)
Default RE: Roll axis trim changes with airspeed change.
I had a Boomerang XL with the same problem. You need to check the incidence on both wings . I found one off. I adjusted the pin at the leading edge area. It might be more difficult with your plane. Throttle to aileron mix will not work well because we do not fly at a consent power setting. Dan
