RCU Forums - View Single Post - Roll axis trim changes with airspeed change.
Old 09-21-2011 | 06:54 PM
TimT2000's Avatar
TimT2000
Default RE: Roll axis trim changes with airspeed change.
ORIGINAL: Rich_C
Have you checked the lateral( left right) balance of the plane? If for whatever reason one side is heavier than the other if will need lots of trim at low speed to produce the required correction, whereas at high speed it will need very little, which sounds like the problem you have.
Rich.
Yup, I have seen this.. +1
Tim
