RCU Forums - View Single Post - motor issues
Thread: motor issues
Old 09-21-2011 | 10:13 PM
Mr67Stang's Avatar
Mr67Stang
Default RE: motor issues
ORIGINAL: Melnick123
What happens if the throttle esc only works in the thottle ( #3) slot of the reciver but not in the other slots. </p>
This question is a little vague. Why would you want the throttle on another channel? Have you tried to use the ESC in another channel and discovered it does not work? The biggest differense I can think of is the other 3 channels usually used for rudder/elevator/aileron all have springs on the stick with zero being in there relaxed center positions while the throttle's zero is in the all the way down position.
