RE: Roll axis trim changes with airspeed change.
Dan,
I can give two or three reasons why a throttle mix is not a good solution. Its a band aid and it wont even work right. I wouldnt be suprised if the incidence is off from one wing to the other. If it is it will be very hard to fix on this airplane. I will try to check it out later today.
