RE: Goose's Aeroworks ProX260 build thread
A1pcfixer,
I adjusted my Ailerons again for perfect 0 degrees and they are within 1/2 turn on the clevis. Aileron Diff is 0/0 where before I had some in a right roll so I may of had one or both ailerons slightly off.
I added CF gear, dropped the SFG, added a chrome plated brass Dubro spinner nut and GP 1oz weight. I now have 2.5 oz of weight on the nose so it's getting better. I'm going to remove another 1/2 oz for the next flight. As my fuel burns off the CG moves aft and it's getting real close to where I want it.
All,
How much elevator throw are you guys using on Low Rate? I have mine set at 17 degrees and with a slightly forward CG (Nose drops slightly with 1/2 tank on an inverted 45 degree upline) but it seems very touchy. I'm using an 11X with 35% EXPO for smooth IMAC flying but man is the elevator touchy with such little throw. It can do a loop with 20 feet at normal cruise speed.
