RCU Forums - View Single Post - Inrunner stuff
Old 09-22-2011 | 06:37 AM
smcharg's Avatar
smcharg
Default RE: Inrunner stuff
Joe,
You probably already mentioned but Imissed the type of plane you have this motor in. That prop is rather small in comparison to what a lot of us run. Your plane will dictate what you run but that motor will turn, at the very least (as I've tried them all) these props:
APC 20x15
20.5x14
22x12
Falcon 21x14
Obviously, it'll turn a lot more but those are the props I've tried. I'm surprised you have to go full throttle (or maybe this was just a ground check).
Good luck at the contest!
