RCU Forums - View Single Post - How ? Remove old covering from Airframe
Old 09-22-2011 | 01:28 PM
t34pilot
Default RE: How ? Remove old covering from Airframe
What type of heat gun are you supposed to use? Is it one that you would buy at a hobby shop or would a hand held hair dryer possibly be used?
ORIGINAL: goirish
when you are using the heat gun don't let the covering get to hot. I normally set my heat on the low setting. Just warm it up in front of where you are pulling the covering off. I then will use acetone to get rid of some the small pieces that wants to stick. Just take your time.
