RCU Forums - View Single Post - Roll axis trim changes with airspeed change.
Old 09-22-2011 | 06:04 PM
  #35
FalconWings's Avatar
FalconWings
My Feedback: (57)
Default RE: Roll axis trim changes with airspeed change.
ORIGINAL: turnnburn
Dan,
I can give two or three reasons why a throttle mix is not a good solution. Its a band aid and it wont even work right. I wouldnt be suprised if the incidence is off from one wing to the other. If it is it will be very hard to fix on this airplane. I will try to check it out later today.
I can give you another one - throttle is not proportional to speed in any way. Climb at full throttle, then dive at full throttle. Guarantee you will see a difference in speed. ;-)
