Over an hour! That is a lot of stick time. I hope you have a high capacity reciever battery.
I wonder how that compares to 13 oz of gasoline if your OS was converted to run of gasoline. Probably less than the diesel conversion since the compression would have to be lower to run gasoline.
Crankcase oil will be a challenge.
I have seen threads where people had oil circulating (in through the backplate and out the cam cover) through the engine from a tank, but I have never seen anyone actually have the oil just sitting in the crankase.
</p>
