Curare tail
While reading the Tipo construction article Dick mentions that if not using a bottom center mounted pipe, less "droop" should be used on the horizontal stab. IIRC the droop with pipe was 4.5" and without 2". When building the Curare is this cathedral angle constant or determined based upon certain factors? If this hasn't been addressed before, should we consider Dick's suggestion when building a Curare for SPA?
