RCU Forums - View Single Post - compression
Thread: compression
Old 09-23-2011 | 12:48 PM
Truckracer
My Feedback: (19)
Default RE: compression
When turning the engine backwards, the angle of the connecting rod puts side forces on the piston in the same direction as when the engine is running. This more closely matches the ring and piston to normal wear, thrust and alignment patterns in the cylinder than when the engine is turned in the normal direction. Most all engines will have more cranking compression when turned backwards. This is normal.
