ORIGINAL: Pah co chu puk
BIGGTONY How do you plan to do such a complex camo?
I have been thinking about it for some time and today I did a ''bench test'' of my method to see what I could do. The colors I used are not the colors I'm using on the Leo.
I used the workbench as the first color, some tan I had extra of as the second color, and a green as the third color. I used brush instead of the airbrush but I learned some things...
I got some bleed through at the places the tape overlaped.
Tweezers are a must!
This will take a long time to do right.
This will only work if I can touch up the spray with a brush using the same color.
This could look awesome.
A step by step of my method in pix... Advice from others is always a gift, even if you only pass it on.<br type=''_moz'' />
looks good, you just have some bleeding going on.....make sure to press down the painters tape firmly and you will get crisp lines guaranteed
