ORIGINAL: outlander
What engine did you install ? How did the cg. work out ? How far is the engine away
from the firewall ? Do you have any pictures of the engine installation ?
I used a CRRC por 26cc and it pulls it just fine. If you put a 30cc on it, it'll have more than enough power to hover. As far as the CG, I measured 2 3/8" back from the L.E. This puts it a little nose heavy but it works for my use. The back of the prop hub is 5 1/4" from the fire wall. The next time I take the cowling off, I'll take some pictures for you. I hope this helps you out.
J.T.- thanks for calling me out on my messy garage. You know I had help with that. But I'll clean it up just for you.
Donnie
