RE: Redcat Racing Tornado Thread
Out of curiosity.... One other problem that redcat said is "normal" but I don't know.... the plastic body has meltet right at the header and started melting at the muffler... I called redcat and they said the only fix is to cut the body arround where it is burnt.... is this ACUALLY normal? or have i not set something up correctly? I had the body mounted on the lower holes in the rear... they said that is the normal spot to mount the body... Just curious.... or should I investigate a different body for my s30 ? If i trim off all of the burnt plastic, most of the right side of the body will be missing.....
