AFPD and Dynam 6ch Controller
Hello:
My old computer with installed AFPD and controller got stolen. I have the original AFPDCD's so I reinstalled on a new computer running Windows7 64 bit. I also updated to ver 1.11.07.21. I purchased a cheap Dynam 6ch USBcontroller. I know the controller works with W7 since I can calibrate it under the Devices and Printers/PPM. It also works with the Dynam simulator (if you can call it that). The problem is that when I load AFPD it loads to the main page (where you select the airport and plane) and I get a new window saying ".....unable to locate the USBinterface cable / USBGamecommander..." I have pluged into different USBports with no succes(don't think that is the issue). Also, under device manager settings there is NOUSB Gamecommander and obviosuly nothing listed under IKARUSInterface or IKARUSCommander.
Any help provided to help solve this annoying issue is greatly appreciated because the itch to fly R/C airplanes and helicopters is killing me!!
Many thanks in advance.
