RE: Receiver crystals
But re-read the original post - was the question can you use a JR RECEIVER crystal in a Futaba TRANSMITTER.
No. You can't. Receiver crystals are cut to be off of the desired frequency by the amount of the IF in the receiver - and as such, won't transmit on the correct frequency should you put one in a transmitter, even if you did get it to oscillate.
