RCU Forums - View Single Post - Timer set up on FUTABA 10c
Old 09-27-2011 | 06:10 AM
Bax
Default RE: Timer set up on FUTABA 10c
When you use Glider programming, the throttle stick gets assigned to Airbrake (ARB). To keep it as "Throttle", you'll need to use the ACRO menu. You can use that stick to control the timer...why not? How you use the different channels is as arbitrary as you decide.
