RE: Startup Questions, Gas CAT
So you did a duck diving. You strut need to be even with the bottom sponson. Angle the strut. positive will lift the bow. I did notice the 2 auto bailer. you may want to remover them this winter and patch, add trim-tabs over the holes. If you can't get the hull to calm down. Re drill holes in the top of the transom. When you pick the hull up just pour out the water.
