RCU Forums - View Single Post - SIMLA BUILD THREAD
Old 09-29-2011 | 05:52 AM
  #502
billberry189
Default RE: SIMLA BUILD THREAD
Duane,
Thanks much for the information. These discussions on the paint scheme give me an increasingly more accurate view of how it should turn out. You are quite correct about the confusion all the masking tape causes during the process. That is why it is very important to have some guide line measurements to go by. I like to use a soft pencil to lay out my lines. After masking they can be erased, and it gives me a good representation of what the finished scheme is going to look like. It also allows for any needed adjustments.
My schedule right now will cause me to take several weeks to complete the paint scheme. I will take photos as I go and share them with you to get your input. I figure that at this point, taking a little extra time will be well worth it.
Bill
PS- I am using two 5 cell 6volt 2000 Mah batteries; both for redundancey and balancing. I know it is extra weight, but with the 120 AX to over come that extra weight I feel like the added security is worth it as well as the faster servo speed and greater servo torque.
Bye-Bye
