RE: I'm so disappointed with THE QUAKE 8e....
that squeal is the bearing or bushing of the fan, most of the times a tap of it will make it go away, wd can actually clean the grease out of bearings or bushings so i wouldnt suggest it, its good for cleaning. Sounds like you either wired something wrong with the deans, bad connection or your esc is shot.
