ORIGINAL: Weekend Warriors
UPDATE NEW EARTHQUAKE 8E STILL ON THE SHELVE
ok so today i should be able to pin point what's wrong by trial and error...... for some reasom so far the main power line which connects to the battery, the black and red wire, not the red/red wire, is getting very hot and so is the battery that it is connected to........
any ideas?? doesn't seem to matter which battery i used, the main power line and battery connected to it gets hot.....
would a faulty esc do this????
im going to change the battery connectors today and see if that helps...
What ESC does that truck have? Is it the EZ-Run from turnigy, because if it is, pack it up and send it back. I just got a shipment of Ten Turnigy EZ-Run ESCs direct from Turnigy and two of them actually burst into flames on the inside when we hooked up the battery to them, unbelievable.
