RE: Larger Revolver
Wjcalhound
Thank you for your comment on my build. To answer your question, the hatch retainer I had, a BVM part, there is a red one from another company that I prefer, the trick part was to clear the foam and build a base and then glue it to the thing turtle deck and on the fuel filler I was installing the fuel filler I noticed that there was a gap between the nut and the body of the filler I asume it was that way becuse it is mented to be intalled on the side of the fuse, that's why I got a servo wheel as a washer, the other thing is that this is the first time using something like that on my airplanes, I have seen it been use on the big gasers before, it just made sence to instal it there than trying to reroute the fuel line back into the fuese since the front of the fuel tank is near the engine.
