RCU Forums - View Single Post - Larger Revolver
Old 09-30-2011 | 02:21 AM
  #3726
afjetmech
Default RE: Larger Revolver
ORIGINAL: Slow and Steady
Sorry, I don't remember the jumpers or making any adjustments. You can hook up a battery checker to the ignition line coming out of the IBEC to check its voltage before attaching to the ignition. I will be removing the cowl in the next couple of days and will check it out myself. I think the voltage on mine was around 5.6. I will post my findings. Todd, the owner of Syssa, is also very responsive to any email inquiries.
Well looking at the unit there are 4 pins, with two each labled A and B. The A pins are jumped and the B pins are not, with the jumper just stuck on one of them. This is giving 5.3volts output using a Life pack. I'm going to just leave it there. Iassume different configurations change the voltage, just don't have any info on what does what. Ihate just blindly screwing around with new electronics without proper instructions.
