ORIGINAL: afjetmech
ORIGINAL: Slow and Steady
Sorry, I don't remember the jumpers or making any adjustments. You can hook up a battery checker to the ignition line coming out of the IBEC to check its voltage before attaching to the ignition. I will be removing the cowl in the next couple of days and will check it out myself. I think the voltage on mine was around 5.6. I will post my findings. Todd, the owner of Syssa, is also very responsive to any email inquiries.
Well looking at the unit there are 4 pins, with two each labled A and B. The A pins are jumped and the B pins are not, with the jumper just stuck on one of them. This is giving 5.3volts output using a Life pack. I'm going to just leave it there. I assume different configurations change the voltage, just don't have any info on what does what. I hate just blindly screwing around with new electronics without proper instructions.
This is the "Syssa" unit
http://www.tech-aero.net/ultra-ibec from here you can download the user manual...
