RCU Forums - View Single Post - full composite Wind S pro -Sebart
Old 10-01-2011 | 02:41 AM
s-chester
Default RE: full composite Wind S pro -Sebart
on the old model ,the balsa wing - the wing tube in the fuselage after 600 flights was quite weak , had to reinforce it
so I added glass fiber as the tube is inside the fuselage
for prevent the tube to stick, I have added a transparent monokote to the wing tube
The Same process was done for the composite to prevent problems later
ID:	1668432   Click image for larger version
ID:	1668433   Click image for larger version
ID:	1668434   Click image for larger version
ID:	1668435   Click image for larger version
ID:	1668436   Click image for larger version
ID:	1668437   Click image for larger version
ID:	1668438   Click image for larger version
