RE: Larger Revolver
Piled my Revovler in today. I was in a tight climbing circle at WOT (do this a lot) about 40 feet off the ground and then the plane looked like it snapped out and into fast death spiral. As I watched it spiral to the ground in slow motion, I could see one of the elevator halves flapping behind the plane. The CA hinges had pulled out. OK, I'm no longer a CA hinge fan. I had fixed the ailerons with pin hinges due to one of them failing last weekend. Guess I needed to do the elevator halves as well.
I'd like to have another one but I've had this one for a while and would like something a bit more aerobatic. Maybe an Edge, Extra or Yak with a DLE 20 on it.
So you guys continue to carry the Revolver torch!
