RE: Larger Revolver
I have a Funtana 125, which is an unlimited 70" span aerobatic plane and while I really like the power and the way it flies with the Syssa 30, I have also seen it with a DLE 20 doing extensive 3d with plenty of pull out from a hover. At $310 with free shipping, the Funtana is over $100 less than most 30cc gas planes and only 3 inches less in wing span (actual 69.5", with a 69" fuse length). Were it lacks in wing span it makes up in wing area. It flies very light. And the color scheme makes it easy to see, no matter the attitude. The inverted flat spins are totally flat - no pitch. I guess you can tell I like the plane!
Tande, Thanks for the IBEC link. I have downloaded both the stats sheet and manual.
