RCU Forums - View Single Post - LED FLASH??
Thread: LED FLASH??
Old 10-04-2011 | 01:52 PM
shenlonco's Avatar
shenlonco
Default RE: LED FLASH??
Hi Joe the tamiya unit will fry a led ...maybe do it like panther said with the recoil unit make a jumper and power a led off it see what voltage it is ... you can get higher voltage leds or you can use a diod in reverse to lower the voltage or a resistor.
