RCU Forums - View Single Post - Same engine or change
Old 10-04-2011 | 05:26 PM
riot3d
Default RE: Same engine or change
For simplicity, a simple two stroke OS 120 AX should do the job. However, if you're proficient with four strokes especially the YS system, I'll go with the 110 or the replacement 115.
There is still a lot of us here flying YS, & we can provide you with suggestion should you run into trouble.
Good luck.
Adrian
