RCU Forums - View Single Post - Platt Zero Build Thread
Old 10-04-2011 | 08:04 PM
[email protected]
Default RE: Platt Zero Build Thread
Here's one more of the flap toppping and then installing the 1/4" brass contol/hinge.
I toyed with using a CF or alluminum tube instead of brass to save some weight behind the cg, but in the end decided to follow Dave's plan. I figured it was important since he clearly wrote "braised, not soldered" on the plan (and I don't have a mig welder). It will certainly be rugged! I'm using a high-torque HS-645MG Ultra Torque servo to activate the flaps:
Here's all the servos I'm using:
<h2><span class="mw-headline" id="Platt_80.22_A6M_Zero">Platt 80" A6M Zero</span></h2><ul>[*]Flaps: HS-645MG Ultra Torque (32645S)[*]Aileron: Hitec HS-625HB (32625S)[*]Rudder: Hitec HS-635HB (33635S)[*]Elevator: Hitec HS-635HB (33635S)[*]Throttle: HS-81MG Sub Micro (31081S)[*]Drop Tank:GWS "el cheapo"[*]Main Gear (air switch): HS-81 Sub Micro (31081S)[*]Tail Gear (mechanical): HS-75BB Low Profile Retract (31075S)[/list]
ID:	1670149   Click image for larger version
ID:	1670150   Click image for larger version
ID:	1670151   Click image for larger version
ID:	1670152   Click image for larger version
ID:	1670153   Click image for larger version
ID:	1670154   Click image for larger version
ID:	1670155   Click image for larger version
ID:	1670157   Click image for larger version
ID:	1670158   Click image for larger version
