RCU Forums - View Single Post - Platt Zero Build Thread
Old 10-05-2011 | 06:28 PM
[email protected]
Default RE: Platt Zero Build Thread
Resonding to Numblock's question:
<span style="color: rgb(0, 0, 255);">"How large of a wing will the A-Justo-Jig accommodate? And was there a jig included for the holes you drilled into the ribs?
Bob I. <span class="info"> </span> "</span>
Hi Bob,
The Platt Zero has just barely under an 80" wingspan. With the A6M3 wingtips option built as per plan, it will just fit the jig. I wanted the A6M3, but decided not to use such a large solid wingtip, so I extended the jig's rods out a couple inches beyond the jig to hold a last rib #11 per the A6M5 square tip version, but I trimmed it down to the A6M3 profile with a much smaller wingtip block that way.
A-justo-jig rod holes: The plan does not provde drill points for a-justo-jig rod holes. I picked a location that would allow me to use one of the rod holes for the aileron control after I pulled out the rods. This worked great.
I also had to cut two of the jig's rib braces in half so I could remove it with the wing still on the jig where the aileron control horn support goes. I had to do this so I could mount the horn before covering the top of the wing. I made a 1/8" ply plate that fit inside the jig profile and screwwed it together. This turned out to be a neat idea I think... (if they remake a-justo-jigs, as I have seen talk on other forums, this would be a neat standard feature to allow removal of some ribs early...
I hope these pictures make sense after reading this... (grin)
PS. I just found some earlier photos I made when I was figuring out where to drill...
ID:	1670449   Click image for larger version
ID:	1670450   Click image for larger version
ID:	1670451   Click image for larger version
ID:	1670452   Click image for larger version
ID:	1670453   Click image for larger version
ID:	1670454   Click image for larger version
ID:	1670455   Click image for larger version
ID:	1670457   Click image for larger version
ID:	1670458   Click image for larger version
ID:	1670459   Click image for larger version
