RCU Forums - View Single Post - Thinking of going surface
Old 10-05-2011 | 07:55 PM
SyCo_VeNoM's Avatar
SyCo_VeNoM
Default RE: Thinking of going surface
ORIGINAL: zoltarDO
Too funny about the airboat, I will definately keep that in mind. Toledo Ohio area some winters are harsher then others. As for the charger, I think it only charges up to 3000mah which won't cut it for these 3s 5000mah lipos it looks like I am going to have to invest in unless I'm wrong then I would love to know.
good point didn't see you mentioned your charger
assuming you have a 12V power supply (specs I saw on the poly didn't mention it having an AC adapter built in) that can pump out at least 5 amps you can just pick up a cheap turnigy charger from hobbyking for around $24
http://www.hobbyking.com/hobbyking/s...ehouse%5F.html
I use 2 of those hooked up to a cheap server power supply. So far they have been working great for me
