Question about wing joining...
I'm in the process of building a Kadet Mark II - my first build in about 30 years - and am slightly baffled about the best way to join the wing halves.
When joining the wings, what is the best method to keep pressureon the glue joint?
I can't clamp along the length of the root, as the leading edge and trailing edge are sheeted, top and bottom, 3"and 1", respectively. Ican clamp in the center of the root, but I'm afraid of having a loose joint in the areas that are sheeted.
Thanks in advance for any help.
</p>
