RCU Forums - View Single Post - MonoKote will not shrink
Old 10-07-2011 | 07:10 AM
DGrant's Avatar
DGrant
Default RE: MonoKote will not shrink
ORIGINAL: DVI
I purchased a 25' roll of Transparent Red MonoKote and started covering a Sig Kadet model of mine. I tack the edges of the material down and when I used a heat gun to shrink the material it just appeared to loosen up with many more wrinkles than I started with.
I have never had this happen before. Has anyone else had a problem similar problem with shrink material?
It sounds like it simply needs more heat. I heat sometimes to the melting point then back off. Maybe your heat gun is getting weak, or not getting as hot as it should. I've had heat-guns go out slowly, where they just won't get hot enough. It takes a good bit of heat to shrink film... I'd try cranking your iron up, find the point that it melts the film, then back off a touch. I've heard stories about Monokote changing over the years... I'm not quite sure I believe them though, as I've never had any trouble.. and I've recently bought and used new Monokote for a few projects.
Sometimes with film covering, it takes what it takes... as there are variables that come into play, such as environment(we are dealing with heat-sensitive material), the structure being covered(open bay or solid), even down to the tools being used... and I'm not saying anybody else is wrong, or that I'm right here.. but these are all possibilities you might consider.. I wish you well.
