RCU Forums - View Single Post - FYI - Sig to release Rascal 110 kit
Old 10-07-2011 | 08:29 PM
Gray Beard
My Feedback: (-1)
Default RE: FYI - Sig to release Rascal 110 kit
ORIGINAL: jessiej
ORIGINAL: Gray Beard
Well, see there, if someone else cuts it for you then you don't even need to think about what type of glue to use for sticking on the templates. Simple crap sure runs away fast on RCU.
I remember when using an Xacto seemed like cheating after using the razor blade. Time files, din't it?[&o]
jess
Yep, and there were was no die cutting in a lot of kits, the wood was silk screened with a pattern and you cut it out with a single edge. The Rascal was my very first Free Flight kit. About 1959? They started life as a 1/2A kit, solid sheet, no wing ribs, well two under each wing so it gave the sheeting an air foil shape. There were a couple formers in the fuse and a fire wall. That was a great little plane. Looked just like the big new 110 but the wing span was under 36 inches.
