His statement above seems to be opposite to what Got RPM said. Why what Got RPM said does not occur to this guy? If anyone coudl explain, it will be appreciated! Thank you!
The explanation is simple...don't believe everything you read on the internet, particularly what you read in "testimonials" on vendor sites like the one you cited. There is no accountability for comments made there, many are made by hobbyists with almost no experience, and some are made to be purposely misleading. You are far better off relying on specialist forums like this one, although no matter where you go you will find poor information. When I wrote the FE column for RCBM I often received mail from readers challenging what I had written, claiming that "their friend said" I was completely wrong. Whatever. You have to choose your expert and not rely on only one or two. Fortunately with the Internet we all have the opportunity to read a lot of opinions on almost any subject. Then the challenge is to sort through it all to find "the truth".
