RCU Forums - View Single Post - Almost done
Thread: Almost done
Old 10-08-2011 | 09:23 AM
boomerik's Avatar
boomerik
Default RE: Almost done
Hi David
Yeah from the box the kit comes with openings allready made for the barn door ailerons so i filled those openings up and cut out the normal size ailerons i didn`t however clipped the wing/stab tips i just left them straight also because the alerons are the cut out parts of the wing so if i would have done that i would have had to make new ailerons from solid balsa to be able to make the ailerons.
The install is going ok hinged all surfaces yesterday and installed the aileron servo`s and linkages and was planning on putting in the rest of the radio gear this evening i`ll take a picture again when it`s all ready .
Erik
