ORIGINAL: acdii
Just a thought, but before you put your built plane in the air, pickup a BNF or RTF cheap electric to learn with, that way it will be easier to repair when you crash, and not so heartbreaking being one you built. I did just that by getting an ultra micro T-28. and it is a blast to fly, just very small, so a parkflyer is a good choice too. One of my planes I am learning with is an Apprentice 15E, and I had a good 10 lights until I crashed it, into a barn, DOH. I also have an Eflite T-34, which I was going to use as my first plane, until I got it put together and found it was too pretty a plane to beat up, so I got the Apprentice instead. If I had flown the 34 into the barn it would be a scrap pile, the Apprentice though was easily repaired, although I need to replace the wing after all, it is too weak and flexes now.
Now that I have somewhat OK flying skills and planes that can take a beating, I am going to build a P-51 Top Flight kit. I am only suggesting this because flying is fun, but a Botch to learn, and can quickly discourage one from continuing when the plane hits the dirt the wrong way, and it will happen. With a DX6i, you can fly just about any BNF plane out there from the Ultra Micros to the .60 size planes.
This is the route I took, mainly because it was a quick way to get in the air, but also because all I need is a plane radio and a couple batteries with me to fly. Now that I can take off and land, and recover when the plane goes wacky, I can move forward with building one with some power and noise. Electric is nice and convenient, but nothing beats the sound of a fueled motor spinning a prop.
Not sure I agree with this path, although alot of folks are going this way today......two of my friends tried this method and I think they struggled early and crashed more than necessary because of lack of help (In the form of instructor).... so not much can be done about that if you live 100 miles from the nearest club, etc....
But I think the BNF and Ultra Micro's are cool, but small and more likely to be affected by wind, etc.....which in my opinion makes it harder to learn.
Best thing I have ever seen was a 30CC Gas trainer from AMR......nice Kit, a few hundred more than a LT-40 and Nitro setup, but saves you in a few months in Gas.....
As far as help in your area, you can get some help...in the form of Dave's book (HIGHLY recommended) Better to learn the right way than develope a bad habbit and have to break it later....
Get the "One week to solo" manual, trust me
http://www.rcflightschool.com/Manuals_Page.asp
AND get Real Flight Simulator.....
The two of these will help a TON!
Good luck and I have to weight in on the trainer, LT-40 with a .46 is the best starting point for sure, no question.....and once you learn, you can move those servo's and motor into something more sporty like I did (Listed below)(THis plane has my O/S .46 from my trainer and my original DS821 servo's from my first TX unit, My beloved DX7
Have fun.....
