RE: Heavy Lift
Look at the motor specs to see what the amp draw is for the prop you plan to use. Then get a battery with enough capacity to provide those amps. The flight time you're talking about is pretty long though for a heavy lift contest. Most of those are just one circuit around the airfield and a landing. Since you'll be at full throttle the whole time when loaded, are you sure you need to fly for 15 minutes?
