RCU Forums - View Single Post - Newbie RX problem
Old 10-10-2011 | 06:16 PM
jester_s1
Moderator
Default RE: Newbie RX problem
You can answer that question quickly with a cheap little multimeter. It will tell you if there's any voltage at the connector from the BEC. That said, your problem sounds more like a transmitter issue. Two different planes stopped working at the same time. I assume they have different ESC's and receivers? The common link in the situation is the transmitter, so I'd look there first.
