RCU Forums - View Single Post - out of the ordinary
Old 10-10-2011 | 06:25 PM
jester_s1
Moderator
Default RE: out of the ordinary
Kudos for making it work. You don't have the best performing, most efficient or lightest setup in your plane, but it flies. That's the main thing and if you're happy with it you did good. If you ever want to customize a system to a plane to get the best performance you can, opjose is quite knowledgeable and will probably answer your questions again.
