RCU Forums - View Single Post - Newbie RX problem
Old 10-11-2011 | 06:35 AM
jester_s1
Moderator
Default RE: Newbie RX problem
No, the BEC lowers the voltage to supply your receiver and servos. The receiver needs all three wires since that is also your throttle connection.
So you're using the same receiver and ESC in both planes then? And you're getting no receiver response at all? If that's the case it does sound like the BEC on your ESC is defective or has a bad connection.
