Is this too much of an angle?
So I have been researching on the YA15 ARF, I dont want to ask questions that can be answered easily through a search function. At this time I have only come across 2 pictures of the elevator/rudder box assembly. Its mainly the geometry of the elev servo/pushrod that I am concerned about. I am using 8711's with titanium rods and monster ball links on both sides and want to see what you think of this angle between the servo arm and elevator arm. This picture is with the servo mounted in the mounting slot. The gromets and rubbers are not installed on the servo so the height is 1/4" less.
Did you guys remove the eclip and slide the elevator horn/shaft out of th bearing to work on it?
What do you guys think?
Thanks, Pete
