RCU Forums - View Single Post - CMP Katana 140 V2 CG
Thread
10-12-2011 | 05:08 PM
7
Bonified Wingnut
Aug 2007
735
Millington, MI
RE: CMP Katana 140 V2 CG
The weight of the unassembled parts is 12.125 lbs. This Katana does not have much wing area, 992 sq inches. I would like to keep the wieght down.
After 1" it starts to leave a gap, after two inches the cowl would be no longer touching. (see pic)
I put tape 2" behind the original CG range (2" center to center of tape). That puts it about 6 1/2" back on a 15 1/2" cord. The plane will balance at this point even with the servos in their original spot. But to move it forward to the original center it takes 2 lbs on the engine box.. That really seems like a long way back. That is about 42% cord, I checked my Pheonix Models Katana and I fly it at about 35 % cord and it is quite aerobatic. I think I might go ahead with the build an try to epoxy 10 or 12 ounces in the cowl as far forward as I can. Along with moving the engine as far forward as I can and still have the cowl on. Since I don't have the supplies to move servos forward I guess they go where designed. I sure could use another opinion on this. I guess I will sleep on it.
I see the orange one has more wing area even though it has a shorter span and the nose is longer and the gear is farther forward. Why did yours crash?
Thanks for th help so far opjose
Reply
Like
Bonified Wingnut
View Public Profile
Send a private message to Bonified Wingnut
Find More Posts by Bonified Wingnut
View iTrader Profile
