RCU Forums - View Single Post - Skygate/CARF Viperjet
Old 10-12-2011 | 10:20 PM
schroedm's Avatar
schroedm
Default RE: Skygate/CARF Viperjet
Guys,
Good news!!! The winglets and tip tanks will be available! Seems the concern is over the pain of storing/handling a wing with a large wingtip but I'm sure those that want it will overcome that!.......
"We will have both the winglets and the tiptanks as separate parts. The standard wing will be the extended span tip, which can be cut off and the winglet tip installed.
Wingtips will be available, but the straight tips will have to be cut off. It can be done in the factory if it is requested in time. I strongly recommend to remind every customer of the problems which come with extra bulk and size and handling problems with the wing tips... 90% will wish after some time, they kept the straight wings."
Hope this helps! Let me know if you need any more info.
Rgds
Mark
Comp-ARF UK Rep
